Old 01-25-2013, 09:03 AM   #2 (permalink)
user removed
Would the super high readings occur during periods when you are coasting? If so then it might be an indication of DFCO in operation. If not then it could just be that your engine is just using very little fuel to keep rotating while the vehicle demands are non existant, like glidng downhill with your foot off the gas.
regards
Mech
wmjinman (01-25-2013)
