Old 01-25-2013, 10:33 AM   #3 (permalink)
MTXA
Runs with scissors
Spot - '05 Scion XA
90 day: 30.33 mpg (US)
MAF is one of the key inputs the ECM uses in fuel & ignition strategies and should be repaired ASAP, though it would seem highly doubtful that is what is causing the problem with the Scangauge. When I encounter a vehicle with odd electronic issues, the first place I go in diagnostics is to ensure that there is no AC voltage bleed from the alternator. AC voltage makes DC electronics go nutty. Connect a DVOM set on the AC scale to the battery and check the voltage with the engine running. Anything over .02 volts AC is suspect.
The Following User Says Thank You to MTXA For This Useful Post:
wmjinman (01-25-2013)
