Originally Posted by bennelson
Here's what I'm thinking for the throttle.
I'd hack an e-cycle twist throttle, combine it with a stick shift knob, and mount it to the stick.
The driver can then both shift and e-ccelerate with one hand.
Seems to me there's three ways to go about it.
- Add an electric motor to run the power steering.
- Loop and cap off the power steering hoses.
- Replace with a manual steering rack.
Your thoughts on steering for the project?
I'd say the manual steering rack is not compatible with Your e-accelerator idea. Generally, i don't like the e-acc., You should use just the pedal.
This truck will be heavy, what if You need both hands for steering?
