Old 01-25-2013, 02:15 PM   #4 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 43.95 mpg (US)
I think the Scangauge calculates fuel used from the MAF signal. If the MAF is failing, the engine will go into some sort of open loop mode while the Scangauge is working from a garbage MAF signal. That would explain both the trouble code and the goofy Scangauge reading.
You can expect the measured tank mileage to decrease if the engine is in open loop mode.
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
MetroMPG (01-25-2013), wmjinman (01-25-2013)
