Old 01-25-2013, 03:08 PM   #6 (permalink)
user removed
I agree with the others about the MAF sensor being the source of the erratci readings. They generally (MAFs) gradually get a buildup of corrosion and particluate matter that insulate the sensor from the air flow and the ECU goes into a limp down mode where it uses other parameters to regulate fuel flow. Get the MAF situation corrected and you will probably see the readings corrected.
regards
Mech
