Thread
Lean burn Honda Civic sedan: 93 Civic d15z1 swap into LX 4 door (VLX)
01-26-2013, 05:42 PM
123
permalink
slownugly
Burn lean and prosper\\//
VLX
- '93 Honda Civic VLX
90 day:
51.1
mpg (US)
O2 sensor bung welded in. Also got the warm air intake pipe welded in. I need a 45 or 90 degree pipe yet to point it towards the air box
As you can see in the last pic hot exhaust gases will engulf that pipe in the converter and heat the air up in the pipe. Which will then be sucked into the air box via flex tubing. The finishing touches for that are to come as well as the afr gauge install
slownugly
View Public Profile
Send a private message to slownugly
Find More Posts by slownugly
