Thanks haha. The welds could've been nicer around the pipe but I had to fill some gaps. She seals though. I had to throw an old o2 sensor in to plug up the bung. The pipe is out of the way inside the converter so it doesn't block any flow or loose power. Also I drove it for 15 min and stopped to get some food the pipe had plenty of warm air inside of it. Also the inner hole of the tube is facing the block so it will suck hot air off of that after its warm.
