Old 01-27-2013, 02:43 AM   #7 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
It might sputter like crazy... if it does, crack the fuel line to the injector while it's cranking/running and let the fuel dribble out for a second and it should smooth out.
If the engine is bad, there's a chinese copy on eBay for like $700 shipped. They will run on used motor oil after filtering, and I run mine on trans fluid and pretty much anything else, including mixes with raw gas.
The Following User Says Thank You to Christ For This Useful Post:
War_Wagon (01-27-2013)
