Old 01-27-2013, 12:02 PM   #80 (permalink)
KamperBob
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Correct?...
Originally Posted by ChazInMT View Post
I don't know where you read to put the template ground plane in the middle but I firmly believe it is incorrect and will result in a serious pressure differential where a low pressure area will be on the side. It will not be optimal.
This is the correct application.
Can you please explain your reasoning?
Recreation Engineer
