Old 01-28-2013, 02:50 PM   #35 (permalink)
jamesqf
Originally Posted by IamIan View Post
It's the 12 kw/kg power density of the flywheel that is the hard part for beating KERS ... Maybe with some high end capacitors... while the energy density ~22wh/kg of the flywheel is not great ... that 12kw/kg power density of the flywheel is a real monster.
It would seem fairly simple (technically) to build a system with a flywheel as buffer between battery and motor. You'd want a capacity of 2X braking energy from highway speed, and aim to keep it at 1X...
