OK so this means that my cam timing is retarded, what will that mean for my FE. I am running the engine at lower than normal rpms for any given speed, and it runs slightly hotter than normal. it also has a hard time starting in cold temperatures. will bringing the cam timing back to stock timing help with any of these issues? will it be likely to increase power or FE? either would probably be a good thing.
