Old 01-29-2013, 12:03 PM   #5982 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by Vtecsauce View Post
Hey Everyone,
I was able to reprogram my controller..
I just wanted to ask... i'm running a forklift pump motor 9" on a dune buggy with 3s 18p lipo battery.. capable of 700amps+
We see peaks of 500 amps at the motor.. however the battery side only pulling in the 200amp range......
i've tried 75v battery & 100v battery... but it feels like theres no power difference..
we are running 1 - 2 or 1-4 gear ratio, sorry i dont recall of hand...
all software current settings for motor, battery, and current pot in the controller are at there max settings...
am i missing anything else... or is this all the power i will see?
thanks
Check out your duty cycle. If you are seeing 500A at the motor and the same time 200A on the battery you are only at 40% or about 204 on the pwm in the controller.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
