I haven't seen an acceleration chart like that before though. Thanks for posting it. It's interesting to see how high the value in 1st peaks peaks and drops back down before you reach the shift point to second. And what a loss of acceleration it is as you are forced to chose each higher gear. Even at what is eventually the same rpm range.
