Old 01-29-2013, 07:32 PM   #2 (permalink)
c_silva88
o - '84 Ford F150
dosn't the have 85 carb? if so how do you plan on cutting fuel to the cylinders? also it wont idle/run right cause the firing order and probably result in worse fuel milage. just to give you an idea pull the plug wires off the cylinders you plan on deactivating and try to start it.
