Old 01-30-2013, 01:45 PM   #18 (permalink)
kanoshee
cammy - '98 Toyota Camry le
90 day: 29.18 mpg (US)
Originally Posted by c_silva88 View Post
my 84 has a computer controlled carb which uses an o2 sensor to adjust the air/fuel mixture. and even with the computer controlled stuff acting up ( runs extremely rich)i can consistently get 18mpg out of the 4.9. now swapping a 4.9 in place of your 5.0 is straight forward you can use you current wiring and transmission i can walk through the swap as far in what you'll need and what to do wiring wise, i've done a couple.and complete motors can be had for cheap.
why wouldn't you suggest it? ford used the 300 everything including larger dump trucks, many weighing into the 15,000–20,000 pound (7,000–9,000 kg) range. and a 4.9 will out last a 5.0. the 4.9 has a bulletproof reputation and its known for its low end torque by every one .
yeah i find it real hard to believe any v is better than any inline i'm a big inline fan and if i had the money i would put either a straight six or 4 diesel in it. when i was in college there was this 4cyl diesel we had in the shop that we did alot of work on and it just seemed perfect for any fullsize pickup. but they're pretty rare everybody wants power power power! so they get that "cummings" or powerstroke. or whatever else. i believe this little thing was an older Detroit diesel had 2 separate heads and valve covers it was a regular sized industrial engine made to be rebuilt and reliable. doubt the mileage would of been that great but couldn't of been that bad. the V style in design is inferior, it sits always angled and always has to fight against itself
