On the other hand, i always had a thought, that given the vehicles shape, would eventually reach a "max terminal" layer... once the vehicle starts to taper off(if at all), woulnd't the pressure be the same as it was at its peak?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
