Originally Posted by BamZipPow
The side skirts keep the air between the belly pan and the bottom of the truck from bleeding out. My belly pan is a dropped belly pan method. There is about a 5" gap between the bottom of the truck and the top of the belly pan.
When you say 5" dropped, is this across the board, then being a 5" x width increase in frontal area?
or
Is it just that there is a 5" drop between body and lowest crossmember and that's the level you had to set the belly pan at?
and
Did you notice any identifiable improvements with the completion of the belly pan?
