Thanks!!
I did feel the rubber intake tube and it certainly wasn't as warm as the metal tube. They are different materials so it's hard to say. When I get to work tomorrow I'm going to use my infrared thermometer and test some spots with it. A good test would be to cold start it and get iat readings after a minute. Then drive it to operating temp and check it again. Then unhook the warm air and do the same tests and compare.
On a side note my gauge pod shipped and should be here tomorrow or friday
