Old 01-31-2013, 07:53 AM   #221 (permalink)
bhtooefr
Prius - '16 Toyota Prius Three
The other thing is, most chassis designs out there are optimized for the suspension loads to go into different areas than the Edison2 suspension, with no structure whatsoever for where that needs to go.
Aircooled VWs are probably the best bet, simply due to having structure almost exactly where it needs to be for the Edison2 suspension - you could install a modified front beam design with hard points for the Edison2 suspension.
