Thanks, had a look,
so overall there might be a 1-2" drop at the lowest members around the axles.
The view under mine is considerably flatter looking, I have coil springs and the lowest points are the axles which when fully loaded are close to level with the rest of the underside, there are still some cavities that could do with smoothing over, but looking at it, I am feeling that mine could be one of those that could swing either way with a belly pan.
