VSS signal incorrect
I've took a Arduino Nano v3 and added the signals from my ECU (fuel usage) and conditioned VSS signal. Everything seems to work, when I drive a bit it gives me a speed, and a fuelconsumption. The last part seems accurate, but the speed isn't.
While cruising at a constant speed the speed the speed jumps up and down. But what's even more strange, is the first 2-3 stops the speed drops to zero, but after a couple of miles driving the next stop the MPGuino still thinks I'm driving.
Does anyone have a clue what might be wrong?
