Old 02-01-2013, 04:58 PM   #44 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by niky View Post
I did. Twice now. I am still puzzled why you think that it actually disproves my point. Unless you're suggesting that a rocket and its exhaust form a non-inertial frame of reference... because they don't.
Hi niky,
First: I am saying the rocket accelerating is not in an inertial reference frame. If you hold a ball and let it go in side the rocket, it falls as if acted on by an invisible force. If you toss the ball up it follows a parabolic path, not the straight line required by F = ma. But the wikipedia article does say that by adding a "fictional" force (I hate that term) - in this case graviticity (like gravity) you can make a transform that lets you use an inertial frame of reference.
Second: you had said:
In free space, there are no other inertial frames to measure exhaust velocity by.
This is not true. One point made in the wikipedia piece is that for any 2 inertial frames of reference (IFoR from now on) a Galilean transform can be found to relate the displacement and time of the 2 IFoRs. That means in one frame I can find a transform that allows me to measure the speed of an object in any other IFoR.
Not knowing the speed inside one IFoR is not the same as not having a speed. If the rocket is accelerating what you don't know is the initial speed. You can easily compute the additional speed due to the acceleration - this is the speed I care about. And as this speed increases geometrically increasing power to accelerate a given mass at a constant rate is required.
The fact that a legitimate IFoR can be found in which the speed compared to some other object is unknown isn't a feature. If there is some object, another rocket for instance, intersecting with the path of my rocket, I could look out the window and measure our respective velocities, thus expanding the space of interest in my IFoR. Or I could claim that I don't know my speed. When my rocket hits the other rocket then I suddenly know the relative speeds by measuring the sudden deceleraBANG.
The IFoR can always be expanded to include objects you are getting nearer to or farther from - and hence you can always know your speed.
In the case of the train and bullet, which I don't see why you thought that was interesting, people on the train know it is going 1000 mph, people off the train do too. I'll allow that the gun and bullet don't know, but the observer off the train measures the speed of the bullet and can make the simple transform to know what relative velocity the bullet leaves the gun. Nothing there is inconsistent with what I have been saying all along.
But this:
Of course, the inventor claims that the radiation never leaves the device, and that it can produce electricity on deceleration (in spaaaaaace), which means that he has just invented perpetual motion. Since deceleration is merely acceleration in the opposite direction.
is stupid. Does regenerative braking imply perpetual motion? From looking at the Maxwell's equations basis of the theory it looks like their power efficiency is below 10%
Edit - I just reread the original em drive paper, and they claim that with wave guide Q = 50,000 which is currently available, efficiency is 60% (I had mistaken it as 6%) - remember this is not the efficiency of the engine, but more like the gearbox.
-mort
