Old 02-01-2013, 06:34 PM   #2 (permalink)
aerohead
can?
Originally Posted by damunk View Post
Hello guys,
Do you think with: (full bellypan)
1)Front undertray - with specially shaped (mercedes sls - Curved shape with exit deflectors behind wheel) wheel wind deflectors
2)middle tray - with rear wheel wind deflectors
3)rear diffuser
4)car lowered - sports look
5)wheel wells filled from inside to reduce further gap
Can reduce CD from 0.33 to 0.28 on a hatchback car? I know this question is difficult to be accurate but with some of you guys with years of experience I am sure you would have done calculations and more calculations to get a general idea and that is what I am asking for. Do you think 0.30 is more realistic.
I feel 0.28 would see not only FE significant gain but also small Performance gain. 0.05 reduction asking too much for a really well designed under body?
It's going to be an 'it depends' situation.
If the vehicle was a body-on-frame construction like a JEEP Wrangler, the underside would be sufficiently horrible enough that a belly pan alone might get you to Cd 0.29.
If it's a contemporary unitized chassis,the manufacturer may have already done quite a bit of cleanup under there.So it's 'iffy' with respect to the underside.
The lower the drag of the base vehicle,the more important the wheels,and there influence to overall drag.Ford Motor Company claimed that the inner fenders and wheel spats on their 1984 Probe-IV concept car was good for a 9% overall drag reduction.So you're barking at the right tree.
Most data published is for a specific vehicle tested however,and may not infer that like behavior can be guaranteed for any other vehicle given the same modification.
The best I can give you is a 'maybe.'
Perhaps you could do a rapid crude prototype,good for a limited lifespan of testing against a known performance baseline.If you see good results,then it's worth the time and effort to properly flesh it out.
damunk (02-02-2013), MetroMPG (02-01-2013)
