Old 02-01-2013, 09:32 PM   #7 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
watch NOX output
Originally Posted by primemover View Post
Anyone have any ideas? My understanding is that most cars shouldn't go open loop until much higher load.
TPS relative to rpm , look at knock retard as well, it may be going to open loop because
the system detects excessive ping followed by knock retard
not the air / fuel map.
swap OEM size wheels and tires back on and re test
or
try a tank of High test to see if knock retard is lessened OR you can get a higher load value prior to changing to open loop
BEFORE chasing ghosts
ultimately
increased drag coupled with change in final drive ratio
changes everything
