Old 02-01-2013, 11:13 PM   #23 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by beatr911 View Post
Read the sparkplug thread. Seems that fancy plantinum and iridium don't actually work as well as good ol copper. The benefit is only longer life.
Thanks! I learned something new. So the deal for the Focus is to use the cheap Autolite 103s, gap to .055" and change them every 15K miles. Easy peasy to change so it shouldn't be a problem. Great find!
My first tank with the ST was a dismal 29. This with a horribly out of alignment suspension, nearly plugged air filter, and some other driveability issues. The best is yet to come!
Question on fuel cut. I don't get decel fuel cut unless the engine gets above like 3000 rpm first, then it will cut to about 1300 or so. Is this normal? Seems it should initiate cut well below 3k.
I also have neutral coasting rpm at like 1900rpm. I have to coast really fast to get the scangauge above 100mpg.
I've heard of some folks running iridiums in Ram trucks, but as you said the advantage is not having to change the plugs as often. I run Champion copper truck plugs with .010" larger gaps.
Originally Posted by mcrews View Post
Beatr,
I drove a Taurus (not sure what yr but the last yr produced) and it didnot reduce the rpms when shifted in neutral.
My RAM is similar. If I select neutral, the engine computer holds at high idle, which is nearly the same rpm it was at in gear. That's why I want to make a fuel cut off, so I can cut the fuel when I like to.
