The prop thrust decreases as speed increases because the propeller is pushing against the air, and can't generate as much thrust at higher air speeds because it has to push harder to generate more thrust.
Much the same as with a driven wheel, except in this case, the variable pitch takes the place of gear ratios. Only thing similar for cars would be a CVT.
