Old 02-02-2013, 04:23 AM   #22 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The 3-cyl will bolt up to the transaxle, but there are other changes required to do the swap. You'll need the 3-cyl axles, ECU and maybe wiring harness. I'm not sure about the newer cars, but on the '89-'94 Metro/Swift, the engine mounts on the body are different too. So not a simple fix.
The 8-valve would be almost as much work. It has TBI and will require the correct wiring harness and ECU. Also the valves might not get along with the 16V pistons.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
wmjinman (02-09-2013)
