Old 02-02-2013, 12:54 PM   #4 (permalink)
HilseeJ
TBA - '07 Honda Fit
Originally Posted by Tesla View Post
2 / Where does the air go after it passes through the grill, most cars have gaping holes all around the radiator, best results will be achieved if all other holes are sealed and the radiator is the only exit for air passing through the grille.
If you're talking about the gaps where the radiator stops but the gaps are still there on each side of the grill, then yes, I have that. Are you suggesting blocking the sides?
Other questions (directed towards everyone):
How will I know what the optimal temperature is? Do I want to keep it at the same temperature as what it would be without the grill blocks?
@ Piwoslaw:
How much did that whole automatic setup cost? Even if it's only $20, that seems kinda high considering that's basically a tank of gas.
