Old 02-03-2013, 04:45 AM   #26 (permalink)
jackbauer
jackbauer's Avatar
Here's the latest on the yacht!:
I've attached the arduino sketch in txt format. I'd be grateful if someone could have a look and tell me if it outputs 58 pulses then misses two as i don't have a storage scope at the minute!
File Type: txt crank_v2.txt (779 Bytes, 45 views)
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
a8ksh4 (02-05-2013), mechman600 (02-04-2013)
