Old 02-03-2013, 01:45 PM   #4 (permalink)
88FieroGT
Sounds like you understand what im trying to figure out. However due to valves opening and closing all the way each half revolution of the crankshaft during their operation the spectrum would actually be a 24,000 with no torque load really applied. comparing to pistons would probably be a better comparison since it has the same spectrum at 6k rpms and also load.
I have a design invention that would drastically improve on efficiency but want to make sure it will be reliable enough to be used , even if it turns into a maintanance item so design setup to make an easy swap but I dont see life time less than 150-300 hours being practical what so ever. I have other ideas which I can use in place but this I think is the best setup.
