Old 02-03-2013, 02:38 PM   #26 (permalink)
Tesla
The Truck - '02 Nissan GU Patrol ST
*1 you can base a design around the 'Template' aft-body contour for low drag in a vehicle you can see out of.
*2 you can base a vehicle on a 'Reverse-Template' and achieve drag within 15% of the 'Template',but you won't be able to see out of it.
*3 you can base a vehicle on an ellipsoid and achieve identical drag as the 'Template' but you won't be able to see out of it,park it in a garage,go over a hump,around a corner,etc..
*4 you can base a vehicle on arbitrary legal length requirements and do your best to optimize for that length only,knowing you'll never actually achieve the lowest drag.
I went back and had a look around for some ellipsoid drag data, mainly found info on airships, the one thing was that all these shapes seem to centre on the 2.5 - 4:1 Fineness ratio.
So what's going on there?
If you can take the template or reverse it or use an ellipsoid with the same Fineness ratio and basically get the same drag.
We have a sphere, which I think I read had a Cd of 1, if we put a cone on the front or rear it comes close to the template drag or if we split it and insert a cylinder between the two halves, we again get a drag figure approaching the template.
This has to be related to the boundary layer and it's developement over a distance, the front and rear angles don't change but drag does.
So this suggests to me that in some cases the frontal design may have a significant bearing on the overall drag.
I know that being in the impact/pressure zone there is almost guaranteed attachment with almost any frontal design, but seems to me there is something a bit more subtle there than just plain attachment.
