Old 02-03-2013, 05:44 PM   #4 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Take a look at the timing advance number. I would bet dollars to donuts that the computer is pulling out timing during the lower RPMs. Your ECU is trying to prevent detonation by pulling timing and dumping in the fuel hence the low afr.
Like I said your fuel economy went up because the ECU was finally able to start to add timing as the RPMs went up.
Project Avalon: E bike build
The Following User Says Thank You to razor02097 For This Useful Post:
mcrews (02-06-2013)
