Originally Posted by jamesqf
I plan to, when/if the current bunch of CFLs burn out. But since my oldest ones are early '90s vintage (so old they're not even twisty), that may be a while yet.
I honestly don't think lighting is a major part of my use, though. One fairly large load I do have that you may not is a domestic water well pump, since I'm well away from urban water systems.
But you do support my contention that it's quite possible for most people to reduce their electric (and fossil fuel) consumption significantly, without adversely affecting their quality of life. I'm sure that I could (and will, as I have time) figure out even more ways to reduce my consumption, as for instance adding solar hot water.
You can get low energy ground water pumps from Grundfoss. Even ones that run on PV panels.
