Continuously variable transmission - Wikipedia, the free encyclopedia
A continuously variable transmission makes the concept of combining the equations for power and energy very obvious.
Power = Mass * Acceleration * Velocity
When you grab full throttle with a CVT, the transmission is controlled to change down to a lower ratio and wind the engine up to the power peak rpm. Where the rpm stays for the whole run until you let off the throttle. The CVT then continuously varies the gear ratio longer and longer to keep the same engine rpm while the vehicle Velocity is increasing from the Acceleration.
The the throttle is held fully open by the rider and the engine will be kept at the same rpm by the transmission so the power from the engine is the same throughout the run even though the Velocity is increasing. The transmission is trading torque multiplication for speed as it moves up through it's range of gearing by squeezing the belt up in the front to make the engine pulley bigger and the wheel pulley smaller. The Power at the wheel is the same the whole time but there is less and less rear wheel Torque as Velocity increases.
P = M*A*V
Power stayed the same. And Mass stayed the same. So as the Velocity increases, the Acceleration and the Velocity must trade. One goes down if the other one goes up. Because the Energy that is added by the engine Power over time is linear. 1, 2, 3, 4. Going back to the Energy equation
E = 1/2M*V^2
Energy would have to increase exponentially to keep the same Acceleration as Velocity increases. 1, 4, 9, 16.
