Old 02-05-2013, 12:23 AM   #9 (permalink)
dmodified1
Eco noob
actually thats not a bad idea use a system like the volt, hybrid tech not drive. have an I4 turbo diesel powering two HI output "exhaust driven" alternators. The alternators then power the electric drive of the vehicle. the obvious problem is heat to help this issue 2 generators would be used if more power would be needed the rpm of the diesel motor would be ramped up
