Old 02-05-2013, 12:08 AM   #10 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
no, back pressure is bad almost always
..."Cars need [in many cases, for optimum use] back pressure"...
engines ?
do not need back pressure in the exhaust , less back pressure is always better (except during decel)
which is one reason some users of
engines
use
headers , to minimize and or completely eliminate exhaust back pressure at certain
designed for rpm / load conditions
but
on decel
back pressure in the exhaust is irrelevant OR desired for braking purposes
and the engine intake has high vacuum during decel , so it would be easy to use vacuum to switch a valve to direct exhaust flow to spin an alternator
during decel only
The Following 2 Users Say Thank You to mwebb For This Useful Post:
Christ (02-05-2013), t vago (02-06-2013)
