Old 02-05-2013, 04:35 PM   #32 (permalink)
jackbauer
jackbauer's Avatar
Yes the tach will read motor speed above 300rpm. The motor will have a 2 pulse per rev signal being fed to the arduino. this will do the math to turn that into a 60-2 reluctor wheel signal and feed it to the ecu. When the actual motor revs drop below 300rpm the arduino will maintain a 300rev signal to the ecu. Then when the motor revs over 300rpm it will revert to actual. Hope that makes sense
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
