Thread: 91 civic si
Old 02-06-2013, 12:21 AM   #16 (permalink)
War_Wagon
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
It probably doesn't match up because you have aftermarket wheels and tires that aren't factory sized. If you are trying to figure out your gear ratio based on RPM and speed in a certain gear, and comparing that to factory specs, you need to be using a tire with the diameter of the factory equipped tire. If you measure the diameter of your tire, compare it to the diameter of the factory equipped size, then use that difference as the percentage of correction for your results, you will have a better chance of figuring out what gear ratio you have.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
