Originally Posted by 2000neon
I'm shocked, I had no idea that the tapered in that much at the top of the cab. Now I'm wondering if that is just this generation of truck, or all of them. Now I want to see one on the road to take a closer look at one.
Of course this is all assuming that I've applied the template correctly, if I have not, I will gladly accept criticism and advise on how to do it better.
Yep, my truck is basically identical to that. (so will all 02/03-08 RAMs) The doors slant in from the bottom of the windows up... But seeing the template applied like you did really brings it out!
[edit] Vekke, if you have modded your vehicle to that shape, nice work. I'll defer on the template match to those more acquainted with it...
