I have had the sumitomo htr t4's in the 165 width for about 50 thousand miles now on my vx. replaced two that wore faster than the other about 10k miles ago. the wear was my fault, not rotating as much as I should have been. I woild also say to try and stay with the 13" enkeis that you already have on there, they are some of the lightest wheels you can find. I like the sumitomos. they are cheap and the max sidewall says 51 psi so you cango that high or higherand let em rolllllll.
