Old 02-07-2013, 02:32 AM   #3 (permalink)
retepsnikrep
You can flash the codes out using the ima light and the paperclip methiod at the obdII plug. You'll have to dig about for the two pins to connect together but reading the blink codes is covered on the IC forum. Have a search about for insight/hch1 reading blink codes.
I suspect a bad rebuild. Did they use brand new cells or used ones? Anyway sounds like they should be sorting it out it must have a warranty of some sort.
I do battery rebuilds and never rebuild batteries with old cells now it's simply too unreliable and time consuming. I just replace them with a new set of brand new 8ah ones. Much better !
The Following User Says Thank You to retepsnikrep For This Useful Post:
MetroMPG (02-07-2013)
