Originally Posted by razor02097
If you are going to buy a commuter be sure you will actually save money.. Look at it realistically. If you are only going to drive your smaller car during certain months you might have to break up the mileage between the two.
You also have to insure it, fix it, maintain it, etc... It would add up to a LOT of fuel for your truck.
He also has tires on his truck that could very well cost $1,000 for a set and if they are anything like the truck tires we have at work, you replace them twice as often as car tires.
It's not just the fuel that makes trucks expensive to drive, but as it is, 15,000 miles per year at 15mpg is $3,500 in fuel, even 40mpg is $1,300 or a $2,200 savings just in fuel!
