Old 02-08-2013, 05:25 PM   #19 (permalink)
ultimx
Originally Posted by coyoteX View Post
What CRX model do you have, Si, DX or HF? The differentials make all the difference in the world. What are your RPM's at 60 mph? The best gauge you can add to any car to help in learning how to use your right foot is a vacuum gauge. The larger the better. Slight adjustments in throttle position can make huge fluctuations in vacuum. Learn to read the terrain ahead, adjust the throttle before you get there, let off the throttle and accelerate. I think my best tank was 84 mpg.
I have a hf. Rpms are ~1750 @60. So the only mods u have done are the grill block, rear defuser, and tire splats? That's really exceptional for just the stuff u have I would like to try and replicate that mpg if I could. Eventually I am going to be making an under belly pan and grill block with wheel covers as well.
