Thread: No DFCO?
Old 02-08-2013, 11:05 PM   #12 (permalink)
type-S EF awd
Gasser - '94 Honda Civic VX
fuel cutoff can have many triggers, my honda ecu, at least with the neptune software has triggers of: Load(manifold pressure), Throttle position, RPM, and Speed. I can also Adjust a delay.
On this 94 no option auto civic, I installed a wideband a day before hacking the ECU and noticed no fuel cut. I saw once I got running paramaters that closed throttle was seen as 4%, the stock threshold for fuel cut. Zeroed the TPS and Wahla, fuel cut, its instantaious, and all the way down to ~37mph. It releases the TCC upon decell now, and allows more throttle input before releasing the TCC.
I know this is not helpfull directly for you, as I think your truck is drive by wire, but GM has had a lot of throttle body faults, so many that we keep a spare or 2 for the mule engine that tests transmissions.
I mainly wrote this so you could see at least what one manufacture uses for parameters, and others who find this thread by search might find this info helpful too.
Good luck! I know how disappointed I was when i saw it wasn't working, its money down the drain and CO emissions for nothing!!!
