my lod is 18% idle and 40% cruising when warmed up. lod works with map sensor. it measures vacuum against atmospheric pressure. so if your car doesnt have a map sensor youre doomed.
here is absolute load xgauge if your load doesnt work:
For CANSF bus:
TXD: 07DF0143
RXF: 044185430000
RXD: 2810
MTH:00C800330000
NAM: ALD
it should be max 95% for na engines and it indicates % maximum torque and volumetric efficiency. ie. at WOT my ALD is 88% at 3000rpm and 95% at 4500rpm, falling off after 5500rpm. my car has both map and maf sensor, so i'm not sure if this xgauge will work if your car doesnt have one of those.
