Old 02-11-2013, 06:03 AM   #6005 (permalink)
zsnemeth
Originally Posted by MPaulHolmes View Post
OK, with everything disconnected, check resistance from M- to B-. But first, pray that it is large...
62.5kOhm
I can stop the motor if i give almost full throttle, then i get an error and the motor start spinning full on again. Working, just kinda opposite way....
Here is the log of 0-full throttle two times with a 12V bulb and 5A bat-amps-lim.
At 0 throttle the light is on, as i turn the pot it's getting dimmer, then throw an error (08) and the light is full on again.
Code:
TR=000 CR=000 CF=004 PW=000 HS=0258 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0257 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=002 PW=000 HS=0258 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0258 RT=0713 FB=00 BA=000 AH=000.0
TR=053 CR=088 CF=004 PW=049 HS=0258 RT=0655 FB=00 BA=000 AH=000.0
TR=095 CR=031 CF=002 PW=092 HS=0258 RT=0635 FB=00 BA=000 AH=000.0
TR=178 CR=017 CF=002 PW=149 HS=0258 RT=0596 FB=00 BA=001 AH=000.0
TR=202 CR=016 CF=002 PW=163 HS=0258 RT=0585 FB=00 BA=001 AH=000.0
TR=281 CR=013 CF=002 PW=198 HS=0258 RT=0548 FB=00 BA=001 AH=000.0
TR=293 CR=012 CF=002 PW=208 HS=0258 RT=0542 FB=00 BA=001 AH=000.0
TR=304 CR=010 CF=002 PW=236 HS=0258 RT=0537 FB=00 BA=001 AH=000.0
TR=304 CR=010 CF=002 PW=244 HS=0258 RT=0537 FB=00 BA=000 AH=000.0
TR=304 CR=009 CF=002 PW=268 HS=0258 RT=0537 FB=00 BA=001 AH=000.0
TR=304 CR=009 CF=002 PW=276 HS=0258 RT=0537 FB=00 BA=000 AH=000.0
TR=357 CR=008 CF=000 PW=296 HS=0258 RT=0511 FB=00 BA=000 AH=000.0
TR=378 CR=008 CF=002 PW=303 HS=0258 RT=0502 FB=00 BA=001 AH=000.0
TR=415 CR=007 CF=002 PW=322 HS=0258 RT=0484 FB=00 BA=000 AH=000.0
TR=430 CR=007 CF=002 PW=328 HS=0258 RT=0478 FB=00 BA=001 AH=000.0
TR=472 CR=007 CF=002 PW=345 HS=0259 RT=0458 FB=00 BA=000 AH=000.0
TR=487 CR=007 CF=002 PW=350 HS=0258 RT=0451 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=368 HS=0259 RT=0430 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=372 HS=0258 RT=0423 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=387 HS=0258 RT=0411 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=002 PW=392 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=408 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=000 PW=413 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=429 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=434 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=448 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=452 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=467 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=471 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=486 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=490 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=505 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=000 CF=007 PW=000 HS=0259 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=002 PW=000 HS=0259 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0259 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0259 RT=0411 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0259 RT=0429 FB=08 BA=000 AH=000.0
TR=504 CR=000 CF=004 PW=000 HS=0259 RT=0443 FB=08 BA=000 AH=000.0
TR=398 CR=000 CF=004 PW=000 HS=0259 RT=0493 FB=08 BA=000 AH=000.0
TR=378 CR=000 CF=004 PW=000 HS=0259 RT=0502 FB=08 BA=000 AH=000.0
TR=376 CR=000 CF=002 PW=000 HS=0259 RT=0503 FB=08 BA=000 AH=000.0
TR=157 CR=000 CF=004 PW=000 HS=0259 RT=0607 FB=08 BA=000 AH=000.0
TR=087 CR=000 CF=004 PW=000 HS=0258 RT=0639 FB=08 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0259 RT=0713 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0258 RT=0714 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0259 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0259 RT=0714 FB=00 BA=000 AH=000.0
TR=042 CR=084 CF=004 PW=028 HS=0258 RT=0660 FB=00 BA=000 AH=000.0
TR=123 CR=035 CF=002 PW=086 HS=0259 RT=0621 FB=00 BA=000 AH=000.0
TR=332 CR=018 CF=002 PW=146 HS=0259 RT=0524 FB=00 BA=001 AH=000.0
TR=376 CR=016 CF=002 PW=160 HS=0258 RT=0503 FB=00 BA=001 AH=000.0
TR=476 CR=013 CF=002 PW=196 HS=0259 RT=0456 FB=00 BA=001 AH=000.0
TR=502 CR=012 CF=002 PW=206 HS=0258 RT=0444 FB=00 BA=001 AH=000.0
TR=511 CR=011 CF=002 PW=234 HS=0258 RT=0417 FB=00 BA=000 AH=000.0
TR=511 CR=010 CF=002 PW=242 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=009 CF=002 PW=266 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=009 CF=002 PW=274 HS=0258 RT=0411 FB=00 BA=000 AH=000.0
TR=511 CR=008 CF=002 PW=295 HS=0258 RT=0411 FB=00 BA=000 AH=000.0
TR=511 CR=008 CF=000 PW=301 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=008 CF=002 PW=321 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=007 CF=002 PW=327 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=007 CF=002 PW=343 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=007 CF=002 PW=349 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=007 CF=002 PW=365 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=006 CF=000 PW=370 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=002 PW=384 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=002 PW=389 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=002 PW=403 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=002 PW=408 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=000 PW=423 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=428 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=005 CF=000 PW=441 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=446 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=459 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=464 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=478 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=483 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=497 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=502 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0258 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0257 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=002 PW=000 HS=0257 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=002 PW=000 HS=0257 RT=0411 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0257 RT=0411 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0257 RT=0440 FB=08 BA=000 AH=000.0
TR=485 CR=000 CF=004 PW=000 HS=0257 RT=0452 FB=08 BA=000 AH=000.0
TR=391 CR=000 CF=004 PW=000 HS=0257 RT=0496 FB=08 BA=000 AH=000.0
TR=340 CR=000 CF=004 PW=000 HS=0257 RT=0521 FB=08 BA=000 AH=000.0
TR=106 CR=000 CF=004 PW=000 HS=0257 RT=0630 FB=08 BA=000 AH=000.0
TR=042 CR=000 CF=004 PW=000 HS=0257 RT=0660 FB=08 BA=000 AH=000.0
