It's a pretty simple to check for exhaust restriction. Remove an upstream O2 sensor and screw a 5/8" spark plug adapter from a compression tester into the bung. Connect a vacuum gauge that also reads positive pressure to the adapter. Fire up the engine and observe the gauge. Less than 4" of positive pressure = a serviceable exhaust.
If it ain't broke, why fix it?
