Old 02-11-2013, 02:08 PM   #196 (permalink)
TheSGC
Originally Posted by mechman600 View Post
Any idea what you are going to use for a pump and radiator/heat exchanger? Will it circulate on a 100% duty cycle or will it temperature dependent?
I am going to use the existing radiator since it's already in the EV. I haven't picked out the pump yet, I am going to look at PC water cooling motors or just get another 12v pump like what I am using for my heating system. I haven't decided if it will run 100% or be temp dependent. Most likely I will have it 100%, once my EV is back up and running I am going to monitor more drives and check the temperatures of the Zilla.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
