Thread: Back pressure
Old 02-11-2013, 07:14 PM   #20 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by kanoshee View Post
nothing else on my system is broken?
my exhaust has been welded on and patch so many times it changes from stock pipe to slightly bigger pipe 4 times it has one convertor one resonator and one muffler
Cobbled together exhaust systems put more stress on the o2 sensors and more stress on the catalytic converter because it messes with the exhaust flow, there are plenty of cars out there with 300,000 miles on them that have the original catalytic converter.
If your check engine light is on with a cat code, removing it isn't going to change anything unless you replace it with a working part, replacing it with a working part is only going to last if it's not under abnormal stress.
The Following User Says Thank You to Ryland For This Useful Post:
kanoshee (02-11-2013)
