Old 02-12-2013, 08:38 AM   #57 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by e*clipse View Post
Thanks, Adam - that was a big help.
What is limiting the output voltage? Component capability, the output of sense resistors, or some combination of both?
Thanks again,
E*clipse
In theory, the limit is just bus caps and PFC and output transistor. The voltage sense circuit can be adjusted with different resistor values. The current sensor is good to 100A.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
e*clipse (02-12-2013)
